BCD325P2/BCD996P2: No DMR
KN4UBH
Hello, I have the 996P2 that I let a family member use? I reloaded the the program from RR, but I cannot get the DMR channels to work. All I have are conventional channels. It has been upgraded for the DMR, Firmware 1.08.01. Thanks for the help,
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Be more specific about the app you used - ProScan, ARC-XT or FreeScan? Note that FreeScan doesn't support DMR
Mike
KN4UBH
Sorry, I'm using ARC-XT, 378Z scanner, SUM=18A, using Uniden comm 4, on program. The radio has all the channels there, it's just the DMR are not working.
Wally
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Now let's see what you are trying to load. What is the URL from the database? Mike
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Does ARC-XT have the same capability as FreeScan, to turn off import of certain service tags? That might be one reason you're not seeing your DMR stuff....Mike
KN4UBH
Trying to load Palmetto 800 for Greenville and Laurens county, URL?
KN4UBH
No, I can't get them to pickup, they are loaded, just not coming up, Palmetto 800 P25
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
If I am understanding you correctly, if they are loaded but not scanned, you must add Quick Keys for those 2 areas. Then they should be scanned.
Mike
slayer816
NE Louisiana
You'll want to read those. The Palmetto 800 is a statewide P25 trunking system. DMR is another digital format. Looking over the two counties in question, Greenville lists a few conventional DMR frequencies and Laurens lists none.
The two formats can be trunked or conventional. But they are two different types of digital formats.
JoeBearcat
Uniden Representative
Quick Keys not being assigned should never prevent scanning. Perhaps those Systems/Departments/Channels are locked out.
I'm still trying to figure out if we are talking DMR or P25.
KN4UBH
Hey Mike, I will work on it later, Thank You for your help.
KN4UBH
It's the DMR, conventional P25 will work
slayer816
NE Louisiana
Trunked... but ok. I was confused by your Palmetto 800 reference which is a P25 system. Whatever department you put those channels in, hold on a channel and scroll over till you look through every channel. Do you see the channel in question?
KN4UBH
Yes, I see all the channels that are not scanning,
slayer816
NE Louisiana
Then it "should" be scanning. It's not locked out. There's no avoids present. And you see the channel therefore the qk's (if any) are activated.
What lets you know that it isn't "scanning"?
