Guillaumet
Hello everyone
I have a problem operating a HYTERA RD625 retransmitter with the accessory connector to a phone patch.
(The repeater works very well between portable radios).
When I transmit via the accessory connector (PTT pin 16), the audio reception output becomes muted (Audio RX SLOT 1 pin 24)
Only my TX audio works well (pin 7)
Parameters :
General setting / priority: path priority = PTT
request PTT priority = external PTT Repeat
Request Priority = local repeating Digital
Common / basic: (to avoid TX audio opening delay time at the start of external PTT)
group call hang time = 0.0
private etc. = 0.0
emergency etc = 0.0
The strange thing is that several years ago, I installed dozens of RD625s in DUPLEX on the accessory connector with the parameters above. The device I am trying to program is one of the last ones manufactured (RD625 no longer manufactured) and may be different ?
According to a colleague, the reception cutoff would not be due to audio switching after the CODEC to the RX AF SLOT 1 accessory connector. But to the cutting of the power supply to the entire receiver !!! (the green LED goes out even if we receive) In other words, the RD 625 would now only work in half duplex via the accessory connector.
If you have an idea, thank you very much
Guillaumet
Parameters :
private etc. = 0.0
emergency etc = 0.0
Guillaumet
