Non Rebanding Scanner
Bonkk083
Union, SC
Can non rebanding scanner receive a frequency of 159.4275
Yes. Rebanding ONLY affected the 800MHz band.
When you type in 159.4275, does your scanner try to change that to 159.430, or something else? If so, that may be the step settings are set wrong in your radio.
Bonkk083
Union, SC
On my Pro-2018 it shows 159.427 in big and the 5 was small
Bonkk083
Union, SC
After checking the 159.2375 frequency that I entered it changed it to 159.235 will it receive it because it's way off
ecps92
Taxachusetts
235 and 2375 are not as "WAY OFF" as you may think
IT should work, if near-by, if trying for distance, well then YMMV
I've had agencies 6.25 off or even 12.5 off and heard them on the adjacent freq due to the strong signal
Bonkk083
Union, SC
It's 60-80 miles away
wtp
Port Charlotte FL
can you post the user of that frequency ?
and 80 miles of reception would be quite exceptional.
