regnaleb
Hey there, I'm new here, this is my first question. I Googled alot and you guys seem to be the one who could give me a straight answer. I don't know much about antennas, but I have a biquad antenna that I wish to use for wifi at our secondary house since we are friend with our neighbor and he is willing to let us share his connection. So, frankly, as much as I want to make it work by myself, I'm not into learning the whole antenna theory, I just want a straight answer to my situation, maybe you can help me?
My question is; my 12dbi biquad antenna has an N-Connector on the back of it. I know (from what I read) that I cannot run a long cable from it since I will lose like 1db for each foot of cable. I found out I have a CATV 15db RF amplifier lying around. Using N to F connectors, can I connect my antenna to this amplifier and then output with an F to RP-SMA connector?
The amplifier is a Lindsay Broadband 151-EQ8, 8db Equalizer, 54-1000mhz 15 db, 5-42mhz that powers on with a 15vdc coaxial power supply.
Thanks in advance!
Thanks in advance!
