Not that i needed yet another radio, but....
WSAC829
Mike Oscar 225
EN64ak
Yeah I JUST missed the $99 sale by a few minutes. The conversion is the same as the Anytone at5555 (plus / plus/n). Just hold a few buttons, power on, and select 2band. (I'm at work and can't recall the exact method at the moment). No opening the unit required.
WSAC829
Mike Oscar 225
EN64ak
If anybody is interested, attached is my customized band layout for the HS4 (and its clones).
Just unzip it, then open it with the programming software and write to radio. (back up your original settings first)
A - Stock
B - Stock
C - Stock
D - Modified for channel 1 - channel 60 (26.965 - 27.605) so 27.555 is actually channel 55 on the dial
E - Modified (27.615 - 28.265)
F - Modified for UK 40 FM frequencies
NOTE: The programming software wont let me save the exact UK frequency in, so you'll need to adjust the clarifier/vfo a smidge and change the last digit from 0 to 5 when using this band. Example: UK Channel 23 27.82120 should be 27.82125.
  • HS4-FREEBAND-11M-10M-UK40.zip
bill4long
Indianapolis
I still have a brand new never used Radio Shack TRC-24A that was made in Japan. I have thought about using it since I never have used any channel higher than ch. 21. This model CB radio is the model that if you clip the black wire behind the channel selector switch for the blank channel position you'll be able to use this channel position which was called channel 22A ( blank spot on the channel dial) prior to the implementation of the 40 Ch. Radio. Channel 22A is actually ch. 24 today.
Back in my Van Club days in the 70's, everybody in the Club would run with this model CB and Ch. 22A was our private club channel use because no one else had figured that mod out. The other van clubs would see us using the radio and hear the adjacent channel bleed over but never could figure out what channel
My granddad got me one of these in the 70s. Turned out to be a good radio. It matched up very well with a D-104. I modified it for FreeBand, and drove a 300 watt amp with it. True Confessions!
Sears Road Talker 40 SSB - YouTube
robertwbob
KE0WRU
Northeast jasper county,missouri
Was it built by haitachi? Think i spelled it right? I got a slant face sears roadtalker ssb thats decent yet today.great radios that should still be built in my opinion
