Nothing To Scan
mbrewer1
Gravenhurst, Ontario Canada
Trying to activate my old bcd996t unit which reads "Scan Mode Nothing To Scan". I have tried to upload a channel list using Fssetup 218-6 but the program does not find my unit.
Any help would be appreciated.
CT
Check this list:
good luck!
Check here:
Notes: If no systems are programmed, or all systems (or groups in a system) are locked out or turned off, 'Nothing to Scan' appears. Turn on a system/site quick key or unlock a system/site to scan. If you turn off all groups in a system you will not be able to turn any back on and also see 'Nothing to Scan'. This is a bug that frustrates everybody. In that case, while in Scan mode, press and hold Func (●) to lock function mode. Scroll to the system then press the number of the group quick key(s) you want to enable. Press ● to start scanning then press ● again to unlock function mode."
tvengr
Well Known Member
Baltimore County, MD
If it is not uploading to the scanner, you probably have a communication issue. Click on the Scanner tab in FreeSCAN and Control Scanner. Click on COM Port Setup and Start Auto. It should auto detect your scanner. Close out and try uploading to your scanner again.
