NX-3320 Channel misalignment when channel knob changed while radio is off
Silent99
On the NX-3320 I've seen an issue where if someone changes the channel while the radio is powered off then it becomes out of sync with what channel the radio is actually logically on when the radio is powered back up. To fix you have to turn the radio off and manually select the channel the radio thinks its on. Is there a setting within KPG-D3N to keep this issue from happening? The NX-5300 doesn't appear to have this problem by default.
Do you have the stopper installed on the channel/group select knob?
Do you have only 16 channels programmed per zone?
Do you have the "16 channel zone/channel selector" setting checked?
But, yeah, that's a challenge. My NX-3400 will do the same thing. Usually it doesn't matter to me because I don't rely on the numbers under the knob, I look at the display.
Silent99
No channel stopper installed.
Less than 16 channels and only 1 zone.
No, the "16 channel zone/channel selector" setting is unchecked.
Same.. I have one particular user that is complaining about it.. channel voice announcements are also on but user still doesn't seem to be happy about this scenario.
kd4efm
Florida
Channel stop or channel roll over checked? (End stop and or blank channels after channel X)
dryfb
America
Check 16 channel/zone selector and your issue will be fixed
wd8chl
Uncheck 'rollover' too. If you have less than 16 channels in the zone, and 16 channel/zone is checked, it will start over at one when you get to the last channel.
It's not my way of doing things, but we do have one customer that insisted that everything be in one zone-all 60+ channels. They have to keep spinning and spinning the knob to get to all of them...
