Nx-3820h
M-10
Mobile
I have an kenwood nx-3820h my problem is on dmr I have a local dmr repeater system with multiable repeaters linked together example if the channel I am on is sevenhills tower the radio transmitts fine if the other party is on springhill tower they see my ID but do not hear me. If they change there channel to sevenhills they I can hear me and see my Id Fine I know something has to be changed in the code plug some when if I am on any of 5 repeaters everyone should be able to hear me on those repeaters that are linked can some help through changing the settings in the code plug so it wiil work
Thank you!!
kd4efm
Florida
Lots of unanswered questions
What is the infrastructure network?
What repeaters?
Is this ham related, if so, do you have your OTAA on or off?
*Motorola 8300/8400 with older firmware has issues with passing kenwood OTAA!
Poor networking connections can cause this issue also. Referring to question 1.
Please give a little more insight if you can.
Thanks for chimming in
M-10
Mobile
You were right I unchecked the OTAA and now the motorola dmr system which is a 8400 now is broadcasting my signal over all 5 tower sites and everyone can see my ID and hear my voice !!!
Thank you so much!!! PROBLEM SOLVED BY ONE CHECK BOX.
