NX-5300 K2 Codeplug read error
boonebroadcaster
NKY
Good evening all. Working on some radios, receiving the attached error. Any ideas? KPG-D1N is running 5.10 and the NX-5300k2 is running FPU K 5.10. There is a password on the code plug, which I have. I read a similar forum on an NX5700 issue, but that was regarding a railroad radio and wasn't much help. Any thoughts would be greatly appreciated.
tweiss3
Is it time for Coffee?
Ohio
You may have to play around with enabled modes, but try to get DMR OTAP unchecked.
Also, do you have the cryptographic module installed?
boonebroadcaster
NKY
I'm not sure if there is a cryptographic module installed, however when I read the product information, it does check it. I have tried unchecking both cryptographic and dmr otap with the same results.
@kd4efm, I'm not sure, I honestly doubt it. This is a local FD radio.
tweiss3
Ohio
Perhaps try reflashing firmware? I'm at a loss....
boonebroadcaster
NKY
Confirming there is only one firmware for all of the nx portables (5200,5300,5400). Meaning there isn't a specific firmware file for the 5300 and a different for 5200 or 5400.
WB5UOM
I have seen this on a NX-5700.
I have spent several hours now racking my brain on what I did ,but I did finally get past it. Not sure if I wrote a blank template to it or changed f/w. It was a pain, I remember that much.
ramal121
Lots and lots of watts
Calif Whine Country
I was thinking that, make a codeplug from scratch with everything turned off, write it then read it back to see if that works. But you need the radios' information. I hear you. Is there a sister radio that you can read from and save an archive?
WB5UOM
I am thinking now I wrote the template I wanted to put in it to the radio and then was able to go back and read it back out ok.
