nx-5800 mdc
CHangen702
Henderson, NV
I am using kpg-d1n for programming and can not get pre mdc id to send am I missing something the only spot I see in the software for pre or post id is greyed out when mdc-1200 is selected but un greys when I change it to dtmf. also is there a way for the NX-5800 to decode mdc in decimal, mine is reading all IDS in hex.
kd4efm
EL98 Florida
Go to said channel, channel edit that channel, scroll down to ptt ID in analog section, BOT, EOT, or both is your option.
kd4efm
EL98 Florida
Down at the bottom of the window, you will see com port next to DEC or HEX. Double click on it, change to decimal
