nx1200 help
rcfd34
Dakota IL
so i picked up a kenwood nx1200 from a guy. he says the radio was never programmed brand new so i took it to my local radio guy and when he went to program it it gave him a market code error for programing. i sense have talked to kenwood and they said with these radios there was never a model made for a specific country and that the radio should work where ever. the guy i bought the radio from lived in Canada. can any one help me out with this i dont know what else to do at this point
kd4efm
EL98 Florida
There was some Europe nx1200 being sold around, that may be the issue.
Also, theres protalk versions that look the same, if he has D6 he should be able to read the transceiver info still and see what firmware is in it.
rcfd34
Dakota IL
Is there any way to tell? Other question if it was hooked up to a Canadian software to update firmware or something would that not allow it to be programmed in the usa?
rcfd34
Dakota IL
Talked to the guy I bought it from said it was never programmed or even hooked up to programming software but my local radio said it just keeps giving him a market code error.. even called back to Kenwood again and talked to a very knowledgeable he said he's never heard of this code on this radio ever
I'd be curious if he was actually using the correct software. That appears to be a US market radio from what I can tell. Nothing seems incorrect looking at the label. I hate to blame it on the tech, but sure seems like the issue is on the software end. I programmed a bunch of those recently and didn't have any problems at all with the KPG-D6N.
rcfd34
Dakota IL
He said that's what he was using I'm gonna try to find some one else and see what happens
Vern
Union County, GA
I see in the photo that the model number above the barcode has a "D" in it. If I'm not mistaken, that indicates DMR firmware. If your radio guy was trying to program NXDN channels in it, that might account for an error or perhaps he didn't select the correct model in the dropdown box in KPG-D6N.
Also, the serial number starting with "C01" indicates a manufacture date code of 2020-January (for whatever that's worth). Hope you resolve issue as that's a nice model.
rcfd34
Dakota IL
Does any one know what it would cost for me just to get my own software and programming cord I've done plenty of radios before but have been all free software that people have sent me once I bought the radios from them
KPG-D6NK NX-1x00 series programming software list price is $104.00
KPT-300LMC software license authentication software <free>
KPG-22UM USB - two pin programming cable list price $162.00
There's no way around the cost of the programming software. That is -list- price though, so with some haggling you should be able to drop that price down a bit. Under state contracts, there's usually a certain percentage off the top, but as an individual, you won't qualify for those.
The KPT-300LMC is free and is required to register the software. Don't let a dealer charge you for that. You'll also need the directions on how to activate the software, the dealer can provide that.
The KPG-22UM is a nice cable, but you can find after market ones cheaper.
The software is similar to earlier versions, and no where as hard to learn as KPG-D3N or KPG-D1N. It's very similar to KPG-111 and the older type windows software.
rcfd34
Dakota IL
104 bucks might just be worth it.. can I get it direct from Kenwood or do I have to go to a dealer
EWC_BDN
If it did come from canada it would be able to do wide band. We use KPG-D6 in canada and not D6N
rcfd34
Dakota IL
So would that make it not able to be read? I'm pretty sure the guy I bought it from said he used the d6n to make sure it worked b4 he sent it out
My experience is that the non-N software will read it, but will show and error and switch the wide band stuff to narrow. Never had a radio no be able to be read due to software version levels. It'll at minimum read it and give you an error message. Since the guy who tried to program yours said it wouldn't do anything, I suspect he had a cable or computer issue.
rcfd34
Dakota IL
I know he programmed like 6 other radios while I was there but for some reason mine kept giving him that market code or w.e it was exactly I just wanna make sure before I buy software I'm not gonna have the same issue
Well, since we don't know what caused it, I don't think anyone can rightly tell you if new software will work or not. People have been known to buy radios new and then bork them up by trying to do things incorrectly. It's a really new radio model and new software, so it would be easy for someone to not understand how it works.
It would be a long shot, and take some trust on your part, but sending it to one of us that has D6N and letting us give it a try and see the error for ourselves would be an option.
At minimum, I'd get the guy to try again, and if it pukes when he tries to read it, having him take a screen shot and send it to you so we can see what it says. So far there isn't much information to go off of, other than "someone tried and got an error. "
