Nx210k Software
Texasranch1
Mount sterling
I have a NX-210k software but cannot find the right program software, is there any chance anyone knows which software I need to program it?
I have that but it doesn’t pull up the nx-210 as the an option for the model
You should be able to connect to the radio, select the comm port, and then read the radio.
If it really is an NX-210, and the correct comm port is set, the software will read the radio and figure out what model it is. Nothing required on your end.
If the software is not doing that, then you may not have the comm port set correctly. Use your Device Manager to find which comm port the USB programming cable is picking, and set KPG-111 correctly.
If the software is giving you an error when you try to read the radio, tell us what the error says, and we can assist you from there.
Texasranch1
Mount sterling
Com port is correct cause my nx-200 works fine. It tells me to check model name an market code
^^^^ that's the information we were missing.
That means one of a possible few things:
Tell us about the NX-200 that does work. Is it a North American market radio (has a K in the model number)?
Usually this error means one (or more) of a few things:
1. Software was activated with a different market code activation key. North American activation keys will start with 111K44———— (or in some cases 111K45)------ If your activation code was something different, then the software was set up for a different market and won't read a North American market radio.
2. The NX-210 isn't a North American market radio. Could have been recased?
3. This is an old Railroad radio, in which case I think you need different software (that is hard to get….).
Texasranch1
Mount sterling
Activation key was 111E44
So that means you activated your software for the European market, and if your NX-200 works with it, it's a European market radio.
The NX-210 is probably the K model, as the sticker shows, and you'll need to set up an instance of KPG-111 with the 111K44 activation key.
My NX-200 is a k model an it works I’ve been using it for years. It’s also got the K firmware.
With the E activation key, it's running in Europe market mode. If the NX-200 is working with it, its possible you have a radio that's been recased.
The market code mismatch between the software and the NX-210 explains the error code you are getting.
