R_Rabbit10
- Joined
- Mar 9, 2013
- Messages
- 39
I've been experiencing an issue with four radios developing over the past 3 months. The two NX5200 models (manufactured in May 2020) and two NX5400 models (manufactured in October 2018) are all exhibiting the same problem.
When I press the PTT button to transmit, the transmission cuts off after around 2 seconds. This is happening consistently across all four of my radios.
I've reached out to my dealer to see if they can diagnose and fix this issue, but so far they haven't been able to resolve it.
I'm curious if anyone else has encountered a similar problem with these radio models. If so, were you able to find a solution? Given that multiple radios of different models and ages are now experiencing the same transmission cutoff, I'm concerned this may be a more widespread issue that could eventually affect all of my radios.
Any insight or advice the community can provide would be greatly appreciated as I try to get these radios working reliably again. Thank you in advance for your help!
