NXDN now in my county What do I do? I
slicerwizard
Toronto, Ontario
Dongles can be complicated to set up, especially for beginners,
Someone can walk the OP through it. Just depends on how bad he/she wants it.
plus a tapped scanner has much greater signal sensitivity than any dongle.
If the tap is done properly. Good luck troubleshooting that if it's not done right. And then what? DSD+ has to be set up. If that can be done, so can a dongle.
Bottom line: the OP isn't going to tap a scanner and the extra sensitivity may not be required anyway. A $20 investment in a dongle or a lot more for a Kenwood radio or an NXDN capable scanner. Maybe the OP can afford the US$550+ for a Whistler scanner plus programming. If money is no object, that's definitely his/her best route. Otherwise, it's pretty much the $20 dongle or do without. OP's call.
wbswetnam
DMR-istan
To each his own... I've tried both and I've had much better luck with using tapped scanners than the dongle. I've had three tapped scanners: a RS Pro-96, a RS Pro-405, and a Uniden 142XL. The first two I managed to tap myself because the tapping point was extremely easy to access, but the Uniden 142XL I had done by a professional. I am glad that we have two major choices in how to approach the issue of decoding digital signals.
Here in the South it seems that non-P25 has become much more common than in the Northern states, so as long as us radio enthusiasts have some form of work-around to decode DMR, NXDN and other non-P25 signals I guess we're all happy.
If I were there living in Jessamine County, KY for sure I'd have my Uniden 142XL cranking away with DSD+ to monitor the local county radio traffic, but as I said before, to each his own.
KG4EMJ
Central Kentucky
I got on eBay and bought a new Kenwood portable still sealed in the box. I then (with help from wonderful forum members here) located the proper software CD on eBay ($20) and a cable to connect the radio to my laptop ($15) and I programmed the radio myself.
I now can monitor Fire, EMS, Board of Ed, utilities, highway dept, etc. and I'm loving it. The local PD encrypted their channels which I don't care about too much...if anything serious is going on EMS is usually dispatched anyway and I hear that.
Overall, this was the easiest way to do it. And, I have less money invested than you'd spend on a new scanner.
I am a lineman for the county.
I think you guys are missing the point. The Original Poster stated that she had to pay someone to program her scanner originally. I doubt she's going to be able to purchase a suitable radio off e-Bay, find the software, cable and program it up herself successfully.
