racingfan360
- Joined
- Dec 19, 2005
- Messages
- 1,229
- Reaction score
- 253
Hi, I'm looking for some practical advice based on your actual experience.....a lack of multiple NXDN transmitters nearby make this more tricky for me to test exhaustively on my own. Also, I'm in Europe so there's no FCC/database to help out. I use ARC536Pro, but the manual doesn't help on NXDN setups.......
Away from home, I wish to monitor a group of NXDN Conventional repeaters at a location. The frequencies they will use will be drawn from a known but larger pool of frequencies. I just don't know which of those channels will be in use until I get there. This is all very easy to setup and scan as a Conventional system. But they also use CallerID, and I want to see that info. This is where I need help please:
1. If I setup as a NXDN One Frequency System, can anyone confirm (a) do i have to setup a new site entry per every frequency I wish to scan (ie site to frequency ratio of 1:1) or (b) can I add multiple frequencies to a single site (ie site to frequency ratio of 1:many). My recollection is that (b) doesn't work.
2. If I setup as a NXDN Trunk System, which I've never done before btw (a) would it work and if so (b) if I add multiple frequencies to a single site (ie site to frequency ratio of 1:many) will that work for this scenario.
There is a pool of over 50 frequencies to chose from so I'm looking for the most efficient way to program this up: method 1a could take some time ! I know I need to enable ID Search and set RAN=Search.
TIA
TIA
