I didn't want them contaminating the landfill.I was being sarcastic, considering it was OpenSky gear.![]()
Sent using Tapatalk
Saginaw County has 4 towers, Genesee County has some 7.
I heard today that Oakland county has decided they will be a "STAND ALONE" P25 System and will not be a part of MPSCS. Seems really silly to continue to be somewhat of an island away from the rest of the state.
So all fire comms encrypted?Oakland County will be building a 31 site Simulcast Motorola P25 system. 700Mhz band. The county will probably join the state MPSCS system on a limited membership giving the county users including Southfield excellent interop communications. Our Pontiac site is also not an MPSCS site giving the state 3 sites in Oakland County. We will be using the other two Romeo and Holly as part of the new system. Hopefully we will be building around September. right now the county is gearing up for negotiations. The County has requested the full 42 cents 911 Surcharge to assist with this effort.
It's an expensive system, it will be encrypted also. Even the P25 fire paging, utilizing the Unication pagers.
Actually looking forward to working with Motorola on this, I am an old Motorola guy, I liked the old 806 system we had, it worked very well. I won't be here long enough to see it completed or even turned on completely because I am retiring in August of 2011 but the time I will be here it will be neat to see.
So here is some real scoop info and as the news used to say "News at 11"
... The county will probably join the state MPSCS system on a limited membership... "
You have to wonder why they want to encrypt everything. What are they hiding? Crime stats?
Part of the issue here, is that all seven counties that surround Oakland operate most public safety comms on MPSCS. Having to use different radios, or go through a reboot process, can be a waste of time, at best.According to Google, Oakland County has a population of approx 1.2 million. As an example, if you look at the Greater Toronto Area (Toronto, Peel, York) that's a population base of over 5 million, which each of those municipalities operating separate encrypted P25 trunked systems. They seem to manage ok with interop. From what I understand they have access to each others systems and likely use an interop talkgroup with a key common to all 3 agencies. So it's possible this new system would just have a set of interop groups available with a common key shared to all users.
1: The cost to develop and implement a totally new system vs adapting to the MPSCS system which has been done numerous times by the other counties
2: The cost to replace all of the fire pagers when the current paging systems work fine.
The conversion to the MPSCS system will meet all the needs of the county. If the Oakland county was not able to raise taxes (cell phone surcharge) what would they do?
There are some 45 municipalities in the county with a few patrolled by MSP and others by the Sheriffs' department. Couple that with a complicated "patch" system like they have now to adjacent agencies is a very risky scenario in the event of a mass response. Shame on Oakland County for putting their personal interests ahead of the public and officer's safety.
