scottabing
I've had a complaint about an intermittent issue where audio is garbled, I'm including a link to see if anyone can identify what may be the issue.
Google Drive Link to Example Audio
Fresh install as of 5/26/20 running on pi4 with NooElec NESDR Smart v4 SDR
./rx.py --args 'rtl' -N 'LNA:35' -M meta.json -S 960000 -x 2 -q 0 -T trunk.tsv -l http:0.0.0.0:8080 -w -v 1 -V -2 2> stderr-stream0.2
This recording occurred with a yagi antenna aimed at the closest simulcast antenna site which is about 4 miles away but I seem to have the similar results with the cheap kit antenna.
It seems to only happen sporadically. In attempting to troubleshoot this, I built a second identical system and ran them side by side. I do not get identical audio on both systems, sometimes it happens on one or the other. Or would be worse on one than it is on the other.
I have very limited background in RF (don't assume I know what I'm doing) and linux but I've gotten this far by following the readme and reading in the forums. OP25 has been awesome, I didn't even know it could work this well!
Very interested in how to reduce the likelihood of these occurrences though as I've hit the end of the road on my googling.
