Ocean County, NJ
Nck1995
NJ
Would anyone have or be willing to share their ProScan file for Ocean County?
I just picked up a BCD996P2 and have been having a heck of a time with missing transmissions and getting NJFFS channels to even pick up.
adamr368
NJ
Check your private messages - I sent you a CSV file from my BCD536HP (that is working) and should help get you started.
adamr368
NJ
It should be noted that both of the sub-sites of the Ocean County P25 System are Simulcast. If you are missing transmissions listening to that, it is a well documented symptom of Simulcast Distortion. Read up on the link below.
100% agreed and I provided that guidance as well. Ironically, the 536HP wouldn't pickup Burlington County or NJICS at home due to linear simulcast distortion, but our place at the shore happens to fall in an area that's biased to a simulcast site so it works perfectly there.
RadioChief55
Your not going to get them with that scanner. I tried, you'll need an SDS 100, 150 or 200. Or a Unication G5 and for about $80 get 2 RTL SDR and set them uo and your golden. I saved a great YouTube video on how to set them up. I run 2 setup's with 2 RTL SDR and they work great.
adamr368
NJ
I've had mixed luck with a non-SDS scanner and LSM but am running a BCD536HP with excellent decode in Beach Haven West. It's got to be location, as I am very close to one of the 2 local towers. NJICS is undecodable but Ocean County comes in full strength.
Nck1995
NJ
Hey folks...
I ended up returning the BCD996P2, and went with the SDS200 that a friend conveniently was offloading for about what I paid for the 996P2.
@RadioChief55 are you saying that I am going to need that program and the two pieces of hardware for the 200 as well, or just for the G5?
RadioChief55
I forgot about the BCD536. I have so many scanners but never had the 536. The 996 line is one of my favorite radios.
Clarky
N/W Florida
On a slightly different topic, what Ops or Tac channels do the Long Beach Island fire departments use? Back in the day, I was a member of Surf City. I now live in Florida and occasionally listen on Broadcastify. I really like their dashboard setup for listening to a trunk system.
robbinsj2
Bridgewater, NJ
You'll want software to program the SDS200, Uniden Sentinel is free or there are others available. Once programmed the SDS200 doesn't need anything else to monitor a P25 system provided there is adequate reception. It would need paid upgrades for DMR and NXDN channels/ systems. If you're mobile then you can consider an SDS200 GPS dongle to enable location-based scanning but if you're using it in a localized setting then there's not much benefit to that.
Frequency1
NYC area
To my knowledge they usually use these 3 channels…
Ocean County P25 trunk…
Fire Ops 2 and Fire Tac 2
510213eeTFire Ops 2Fire Operations 2 (South)Fire-Tac
511213f8TFire Tac 2Fire Tactical 2Fire-Tac
Conventional P25 Simplex…Fireground 2
769.04375 M58B NACOC Fireground 2Fireground 2P25Fire-Tac
howie38
Pemberton NJ
Is that why my BCD436HP will recognize Ocean Co 'simulcast' but won't recognize P25 'Emergency Services' (which has all the fire & EMS stuff)?
BJSCHIEF4900
Surf City NJ
F-OPS 2 primary and F-TAC 2 back up. E-OPS 2 primary and E-EMS 2 back up. Fire ground 4 for on scene. Legacy page for dispatch
