Hello,
On the audio stream that I provide there is a strange background noise which I can't seem to get rid of (it is quite noticeable when there is no audio coming from the scanner/the scanner is idle. When audio is coming from the scanner, it is somewhat noticeable).
The background noise is only on the audio of the actual transmitted stream. It is not on the scanner audio output (ie: if I use the scanner's internal speaker or connect an external one, it is not there).
I do have a ground loop isolator in line on my audio cable. Does anyone happen to have any idea what the cause of this sound might be?
My stream is available here: Monroe County Public Safety Live Scanner Audio
Thanks in advance for any help!
