OHP Troop E Durant
mshadwick
SharkMadwick (K5MCS)
Heavener, OK
I have asked this before, but I am going to attempt again...
Does anyone know of Broadcastify feeds that broadcast OHP Troop E??? I live in Leflore county and lost reception when they switched to 700mhz. I still get OHP troop D, but I live within distance of Cavanal Hill. I am hoping there is a feed that has Troop E. McCurtain County is really getting busy with Hochatown growing....
mikebennett
Sherman, TX
Have you tried the Carter Mountain or Clayton tower sites? I would think you could pick up one of those, particularly if you are located on or around Cavanal Hill. I know the topography around there is all over the place though.
mshadwick
Heavener, OK
I tried both of those towers and was unable to receive. I am not convinced the 800mhz beam antenna I tried is bad...
wmccr
There is no indication that there is a feed for Troop E.
You may know this already, but if not, a solid way to see if there is a feed (other than reading the Broadcastify feed descriptions) for a specific agency is to go to that county in RR>trunked systems>click the trunked system that the agency you want is on>scroll to the agency and look for their TG# (DEC) to be in blue or black. If its blue, that is that agency's specific node to a Broadcastify feed. If its black, likely no feed.
