A new antenna was installed at the top of the Timmins water tower. The verticle portion oval is a smaller version of a VHF trunking series. Not sure what band ... have to get a pic on here for the experts to figure out
Sorry, those flat antennas only transmit encrypted.
...in all seriousness, an antenna doesn't really give you an idea as to what is being transmitted. The same antenna can transmit analog, digital, encrypted, data, etc... The only thing the antenna would be able to tell you is (roughly) the frequency. IE, Low Band, VHF, UHF, etc...
Those are most often very directional microwave antennas, used to connect two points. In many cases they're multiple channel digital circuits and not really scanable. To receive them you not only would need to find their frequency, but also be directly in their path (being off only a few degrees may make the signal too weak to receive). Once those are met, you'd need to find what modulation method they use, encryption, etc.
