Old man need advice...
Litefoot3401
I've been out the cb hobby since 1977. When license days stopped in 75 just couldn't take all the language with my family in the vehicles . Now I'm an old man and found some of my old equipment stored away. Thinking about installing cb at home now as backup to my backup for storms.
In yard have a flag pole by the gazebo it's only 18 feet tall. I have several old antennas but thinking about a 5' firestick (NGP) on top . About 30' away is my roof line at 26 feet in height. Would that block to much of a signal coming in or out ?
WSAC829
Green Bay
While not optimal, it should work just fine. I’m surrounded by huge trees and all i’m using are a Little Wil mag mount and a 102” whip on a mag mount tossed on my metal garage roof. Height of roof is roughly 15 feet. My house and the trees are much taller, but i have no issue hearing or talking locally (up to 25 miles) or shooting “skip”.
Litefoot3401
Thank you both ! Was just looking at friestick... I since the 60's have many old antennas , I'm a pack rat , keeping and repurposing a lot. Being on a pole just thinking about the ground plane , like a car or truck offers for the signal. Also to reach father if I go with NGP system. In an emergency only need to get out 5-6 miles for real help if all else goes down. Power supply is no problem . I have 20% in my home running on 12 volts // tv, ice box , all security lights and more . This is on solar generator with 800 watts panels , 24/7.
Been reading a lot on DIY ground planes , trying not to spend too much at my age. This is only a backup to a backup. Maybe one of my old whip's would do better. If my memory is correct those are 102's. At my age just trying to save on labor . Kept it simple____.
About how far would a whip get on a pole with no ground plane. Or is a ground plane a must to get out even 5-6 miles?
Whats the opinions on handhelds for 5-6 miles , would that be worth it ?
Litefoot3401
That maybe worth a few bucks in the box !
Yes have three that still power up... 23 channels would still work for my plans. Maybe get newer side band in time if my idea works.
Still have old early 70's amp // remember using TV tubes. A keep sake / never sell. As in earlier post I'm a packrat. Think I'm telling my age now.
slowmover
Fort Worth
Easier to start with a good design:
Sirio Antenna GP2745 Ground Plane 27-45 MHz Base Antenna​
Let the collectors have your antique radios (eBay) as it’s not just age, but design.
SSB a nice step up.
No radio of the Carter era is comparable.
See other threads here.
There’s plenty of fun to be had. Don’t limit yourself by $$ to just read around. Learn what’s different than 1977 is the whole point to this post.
One of our contributors can’t find an open channel during latest testing of his 50-year handheld radio quest.
A great number of those heard are not local and are not Skip either.
Great ears and post-2022 spec radio.
nokones
Sun City West, AZ
Oh yes, I remember the TV tube's. I remember testing the tubes at Thrifty Drug and at the same time getting a double scoop ice cream cone for a nickel a scoop.
nokones
Sun City West, AZ
Recently, I just replaced my Cobra 19 DX III with a Cobra 25 LTD Classic AM/FM in my Jeep. Last year I replaced the same Cobra 19 that I originally had in my Pickup before I used it in the Jeep with a Cobra 29 LTD Classic Nightwatch AM/FM. I'm still haven't used the FM yet.
Ever since the CB expanded to 40 Channels, I never have used channels 22-40. I only used 6, 15, 17, 19, and 21 (trucker's channels in California). Now, I monitor 16 when I'm on the trail with my Jeep.
Since, I don't use any of the channels above 21, I thought about using my TRC-24 in the Jeep but I wanted the FM just in case if it ever comes to live in the future.
Litefoot3401
Good thing I like reading. Technology has changed a lot !
But I dint think have to keep up with the big boys to get my 5-6 miles I need to have fun or have ready in an emergency.
merlin
DN32su
On a steel pole it would do rather well, but I would ditch the fiberglass. You would need about an 8 inch extention for the 102", that will give you a better match with no ground radials. The rest is up to your radio.
On a 108" steel pole, think of it as a vertical dipole.
merlin
DN32su
SSB a nice step up.
Well, you know 108" is a quarter wave and ground radials should be 8% longer.
Litefoot3401
Merlin , Haha , I'm catching up every day.
Laying out all I have and a few things I got. Going to test mount all my antennas I have under different weather conditions to see which does what I would like. Never know in real life just because whats on specs is bench tested.
merlin
DN32su
Swap those antennas out for a Wilson 1000M mag mount, it far outperforms the littl wil or any whip.
