Old School Nationwide Frequencies
gman4661
Here are some older frequencies that might be useful. These are all analog UHF/VHF that any CCR or basic scanner should receive.
155.160 - National Search and Rescue (unofficial) - VSAR16
154.280 - Fire Mutual Aid - VFIRE21
155.475 - Formerly called National Law Enforcement Emergency Channel - VLAW31
155.340 - EMS HEAR - VMED28 (still used daily in some areas after about 50 years)
156.800 - Marine Ch. 16 (calling channel, one of many marine frequencies)
151.625 - Red Dot - common itinerant business frequency (color dot radios used to be sold at Sam's Club)
Some of the marine frequencies are used illegally in inland areas. Years ago, I heard a local commercial radio station using a marine channel for mobile communications. Hunters are known to use marine channels in some areas.
Also NOAA, GMRS, FRS and MURS. Some of the MURS frequencies are wide band, others narrow band.
There are many more, most being relatively new. This is a great listing, starting on page 24:
https://www.cisa.gov/sites/default/files/publications/NIFOG Ver 1.6.1A.pdf
Inland and away from "navigable waterways", some VHF marine channels are legally utilized for LMR use.
But, yeah, there's a lot that assume it's "just a fancy CB" and use it anyway.
GTR8000
NY/NJ Database Guy
BEE00
It has become somewhat popular to use certain blocks of maritime frequencies for inland conventional and trunked systems. These licenses normally fall under PC - Public Coast Stations, Auctioned license types. I'm aware of a few counties in NY using them for conventional systems, as well as some trunking in PA using the same pool of frequencies, and the common thread is that they were licensed by Motorola many years ago.
ecps92
Taxachusetts
and even here on the Coast, some of the International Marine are allocated to Public Safety. A few times someone forgot to put the PL back on the Repeater after service resulted in some hefty foreign swearing by fishermen :)
lu81fitter
Marshall County, Illinois
I recognize a couple of those right off the top of my head. 155.475 is used in Illinois. They call it ISPERN. Illinois State Police Emergency Radio Network. It's used as inter-op on vehicle chases, etc., and also gets used if state police get a hit on a wanted criminal. Also 155.340. MERCI. Medical Emergency Communications of Illinois. Ambulance to hospital comms.
PACNWDude
Had this argument with some sites I act as radio administrator for.....everyone wants "National Channels" which them makes me ask, which frequency band is that? I get 800 MHz and UHF T-Band answers usually.
Two good ones to listen to: 808.4875 and 853.4875 MHz....relegated to mostly public safety, but there are other legacy users with licenses noted up to 2032 being authorized to use these nationwide. Some are for crews working with "drones" and other science projects. Might be worth listening.
ecps92
Taxachusetts
No need to program a scanner for the 808 as No one would be using, nor does any radio use it for simplex.
Program ONLY the 853 as it would be either a Repeater or Simplex
KB7MIB
Peoria, AZ.
If you program the 808 frequency, you could pick up mobile/portable transmissions to the repeater, which would indicate that a user is *very* close to your location, and you should look very closely at the vehicles around you if you don't see an obvious marked cruiser.
Any repeater input frequency, VHF/UHF/700/800, could be monitored for this purpose. Unless you have a Uniden scanner that mutes encryption, even if the transmission is encrypted, you'd still know that a LEO is in close proximity to you, even if you didn't know what the transmission was about.
John
Peoria, AZ.
