bruderbell
- Joined
- May 8, 2012
- Messages
- 2
Hi all,
I've enjoyed perusing this site, gleaning what info I can understand. I like to think I'm pretty tech savvy, but I clearly don't understand antennas and RF as well as I'd like.
I purchased a home, and in the attic I found a TV antenna. It looks to be a pretty normal all-band tv antenna like shown here (http://www.homedepot.com/h_d1/N-5yc...?catalogId=10053&langId=-1&keyword=tv+antenna). Well, I got up there and checked it out, wanting to wire it up and use the old beast, but that's where I met my match. The antenna has two connection points on it and there was some really old cable hooked into the two points (I think I've gleamed that this is called "twin lead" as opposed to coaxial cable).
I built a little antenna once and so I have something that looks like this: http://www.amazon.com/Cabletronic-75-300-Antenna-Coaxial-Adapter/dp/B0041IG1AK
Since the antenna didn't have a connector for coax, I thought I better hook that into it and I figured I'd have a working rig...didn't work. It was working on my home-built rig, so I don't believe the adapter is bad.
Is there an existing walkthrough or something to that effect that i can study to figure out how to use this old antenna? I know I could buy a new one, but I'd rather learn how this works and have a go at it. I have a little digital multimeter, if that helps. I didn't see any obvious signs of abuse to the antenna - it's been in the attic after all, so it's seen zero wind and no animal damage sign is present.
Thanks in advance,
bruderbell
Thanks in advance,
bruderbell
