OmniX Multi Band Scanner Model Antenna
rilke67
ALAMOGORDO
I am considering purchasing this antenna. I reside in Alamogordo New Mexico and monitor Holloman AFB and WSMR which are on a digital trunk system but also monitor military aviation in the area. I am currently using a Radio Shack Outdoor VHF-Hi/UHF Scanner Antenna Model: 20-176 which is working ok but am wondering if there is anything to gain by switching to the DPD antenna. DPD Productions - Scanner / Radio Antennas for Commercial & Hobbyist Applications
Thanks to all in advance and Merry Christmas.
Avery93
AL
I'm also considering the same thing; replacing a 20-176 with an Omni-X, and am wondering how good it will be on 150-160 MHz and Mil-Air compared to the 20-176.
That 20-176 is a pretty good antenna considering you can find it for $20 at many Radioshack stores, but I think the wind has finally blown it over and broke it in enough places that its time to upgrade (you have no idea how hard its blowing in Bama right now).:)
FLRAILMAN
Banned
Orange City, Fl.
It's an affordable, quality built antenna that more then serves it's stated purpose. Dave, the owner is also a member here. Try it, you won't be disappointed.
FLRAILMAN
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
A DPD Omni-X is my main antenna. i've never used the RS model you mentioned, but I have often compared the OmniX to my Antennacraft ST-2. The ST-2 does better on low-band VHF (30-50), as I would expect it to. The OmniX does very well on VHF, but the ST-2 edges it out just a hair. The Omni-X does much better on UHF and 800 Mhz than the ST-2.
It all depends on what band you prefer to have better coverage on. If you need VHF-Lo (30-50) performance, your best bet is to get antenna that is known to perform well in that range. Otherwise I think you'd be quite happy with the performance of the OmniX.
the OmniX is terminated with an N-connector, so you'll have to make sure you are able to connect your coax to it by having the appropriate connector on your coax or buy an adaptor.
Mike
elrod
R'ville,IL.
I bought an omni x 2 weeks ago, but the the weather here in Chicagoland has been to crappy to do anything with it. I guess I will have to wait till spring.
jgodeker
Grand Island, Nebraska
I've had a OmniX for over a year now, it's very well built and takes a beating from the weather and holds up very well, good reception. I will buy another OmniX when my scantenna gives out. It well worth the money in my opinion.
J.
fuzzymoto
Just put up my Omni-X today. So far it is outperforming the 20-176 it replaced and the ST-2 that sits on the same mast. I'm also pretty sure it will outlast both!
