OP25 On Pi
toolman60
Anyone have an image of PI SD card with OP25 that has audio pipe back to a Windows or Linux PC. Pi 3 Mod. B.
Have no problems getting OP25 to run.
I bounced my B+ model off of the fireplace . Been fooling with it for days and could never get it to send audio back to pc via Ethernet or get it to connect to BT speaker.
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
I don't have an image, but if you just install Raspian Buster Lite and then proceed with the installation of OP25, I and others can certainly help you get audio piping over to a PC (over UDP) -- using VLC on the Windows end to listen.
Mike
mtindor
FMP24 PRO USER
To pipe audio over UDP from the PI to a windows machine:
On the OP25 commandline, add: -u 23456 -w -W 192.168.0.107
- replace 23456 with the UDP port of your choice and 192.168.0.107 with the IP address of your Windows machine
Then on Windows, install VLC. Then create a desktop shortcut for VLC.
Assuming your VLC is installed in c:\program files (x86)\, edit your VLC desktop shortcut "target" to be:
"C:\Program Files (x86)\VideoLAN\VLC\vlc.exe" --clock-jitter=500 --network-caching=0 --demux=rawaud --rawaud-channels 1 --rawaud-samplerate 8000 udp://@:23456
- again, 23456 should be the same port number you used on the OP25 commandline.
Then, make sure that you go to Control Panel / Windows FIrewall / Advanced and add an Inbound rule allowing access to UDP Port 23456 (or whichever port you choose).
I have OP25 running all the time on a machine. When I feel like listening to it, I just click the VLC shortcut on my desktop.
Mike
R0am3r
Salt Water Conch
Oneida County, NY
toolman60 - I too have OP25 running 24/7 on my Pi. I listen to the audio via VLC on my PC as described by Mike (mtindor). He helped me through the process when I was first playing around with OP25 on a Pi 4. If you get stuck, post your rx.py script (or shell file you use to launch it).
