Hi guys,
Ho boy, between you I see quite a number of ways to introduce signal loss and intermod.
First, any "signal splitter" introduces 3dB loss PER PORT so split 2 ways and you have half the signal, 4 ways and you have 1/4 signal and so forth. One receiver per antenna or use a coaxial switch (not a coax switch) is the only way around loss.
Again with the amplifiers. What better way to introduce intermod than introduce a strong signal and drive a linear amplifier into non-linear operation? That's just in the amplifier itself we're talking about here, then they tend to overload the receiver's front end and the same thing happens, the RF amp turns into a mixer and mixing products show up all over the place.
While there may be bandpass and/or bandstop filters ANY in band or out of band (on another band the amp operates on) the amplifier itself is a "DC to light" device that may be overloaded and driven into non-linear operation if not into saturation.
The bottom line is no matter how "high quality" this amp or active splitter is it is still suceptible to strong signals so unless you live out in the country far away from any and all transmitters you may expect problems. The exception I had great success with was a Motorola preselector, a 5 section helical filter followed by an amp giving 10dB gain. Being highly selective, that is for a 500kHz band segment it made my commercial RCA tranceiver hotter than the devil's butt in summer, but then again it's not made for scanners.
Then nobody has mentioned any noise figures, gee, wonder why. These devices are sold to scanner buffs largly ignorant of the requirements of "weak signal" work that hams have been doing all along on VHF and UHF. Preamplifiers are sold for use on Amateur bands but they have published specs including noise figures, low noise is critical for pulling in weak signals without burying them in noise generated by the amplifier itself.
Then again my experience has shown they're pretty useless for FM reception due to the characteristics of an FM receiver (limiting action). When switched on they bring up the S meter reading but what comes out the speaker sounds just the same as it was originally, the limiters kick in. Oh, they work great on SSB, the one in my IC-706mK2G makes all the difference in the world on 2M and 70cM.
