One crimper to rule them all
PrivatelyJeff
Has more money than sense
Kings County, CA
Or at least be good enough?
Can anyone recommend a crimper that has dies for power pole and various coax? Bonus if it does network cable as well. I’ve looked around but am kinda confused on this.
You won't find one crimper, but you can buy the crimper frame (handles) and then the individual dies for the connectors you need.
Take a look at a company like Techni-tool Techni-Tool: Industrial Supplies, Tools, Soldering & MRO and pick out what you need.
It'll be expensive, stuff from there usually is. You may find it is cheaper to buy individual crimpers for what you need.
I have a number of different models, just worked out that way. There are some pretty good kits out there that will give you a lot of capability for not too much money.
PrivatelyJeff
Kings County, CA
That’s what I’m looking for. I’ve found some that do all the RF cables (with the proper die installed). I just think it would be nice to be able to throw a different set of dies for electrical work.
This is hobbyist quality, but seems to have dies for a wide range of connectors:
I have a very similar kit to that at home. Works just fine for doing RG-58 crimp connectors.
I have a higher end kit for work stuff, but I didn't want to bring that home every time I needed it. After 10 years or so, that kit is still working fine.
JStemann
SE Indiana
I have an earlier version of these that have done very well for me.
PrivatelyJeff
Kings County, CA
So it seems like I’ll need a separate crimper for RF and electrical work then. I was really hoping someone made one that had dies for both.
AK9R
Super Moderator
Central Indiana
The crimper in the link I posted has dies for crimping, according to the description, "Anderson Powerpoles, Molex connectors, Insulated and Uninsulated terminals, PLUS Coax Connectors of all types on LMR-400, 9913, RG-8, RG-213, RG-8X, RG-58, RG-316, RG-174, and more."
Crimping modular connectors (RJ-45, etc.) is a little different since the crimper has to push down the plastic "wedge" that hold the cable and push down the 4, 6, or 8 IDC contacts that push down on the individual wires.
PrivatelyJeff
Kings County, CA
thanks. My bad. I originally looked at the page on phone. Now that I looked again on my iPad, it looks like exactly what I need.
wwhitby
Autauga County, Alabama
I just usually end up buying the crimpers I need for whatever I am working on. Yes, I've ended up with quite a few crimpers over the years....
Andersen die sets for power poles are on ebay and amazon. They fit standard ratchet crimper holders. Die Set For Crimping 15/30/45 Amp Anderson Power Pole Type & Similar Connectors | eBay There's lots more.
Something I learned recently. I have a battery box set up with Power Pole connectors for input and output. While removing the float charger that also has Power Poles on the wires, I broke one of the PP connectors off the wire. Not having my PP crimpers handy, I tried using my old butt connector crimpers. To my surprise, it worked really well!
PrivatelyJeff
Kings County, CA
I’ve done that but my electrical/RF tool box is tight on space. I imagine that a butt crimper would work for the PP connectors but I like to do things right because usually when things break/come loose, it’s at the VERY wrong time. My plan is to convert all my standard accessory outlet plugs to PP for better security when I plug things in to outlets.
AK9R
Super Moderator
Central Indiana
This Klein crimping tool (about $30) will work for Anderson Power Poles, but you have to be careful to not over-crush the barrel of the terminal:
wa8pyr
Staff member
Lead Database Admin
Ohio
Ditto, but in the long run it's been cheaper and easier to just get the individual crimpers. Besides, back in the day when I was buying crimpers (most of the ones in my tool bag have been there for for 20 years or more), a "UniCrimper" wasn't really available and by the time one was, I already had nearly everything I needed. All I had to buy was the PowerPole crimper.
PrivatelyJeff
Kings County, CA
Crimpers or dies?
I have two ratchet handle holders (crimpers?) and about a dozen different die sets that interchangeably fit in the holders.
I guess both? I’m new to this. I guess what I’m looking for is holders and compatible dies? Are they all universal?
PrivatelyJeff
Kings County, CA
As a practical matter, having a single crimper frame and needing to change dies frequently gets really old, really fast. Even if you're just an active hobbyist, multiple crimpers are the way to go (within reason, of course!).
it wouldn’t be that frequent. Maybe 1-2 times a year for each die. The reason I want one is that my tool box is full (in the most literal of sense) and I don’t have space for multiple crimpers.
