One voice
robertpearsall
Edison, NJ
Does anyone have a hpd file for one voice I can not for the life of me get it working on my 436.Before anyone ask yes I have the DMR key and latest firmware.
Thanks in advance.
W2SJW
Senior Member
Northwest NJ
With that many sites, I'm waiting for the final firmware & DB import feature before I even consider tackling that system!
W2SJW
Senior Member
Northwest NJ
I'm not sneezing at all on the RC-builds, I've been involved since the betas.
I was listening just yesterday to a Con+ system in the Lehigh Valley. Let me know what site you want and I'll whip up a FL for you...
Sent from my Galaxy S6 via Tapatalk 5
W2SJW
Senior Member
Northwest NJ
OK, here you go. Make sure you're running the RC3 firmware & using the latest Sentinel that came with it (1.07.03). This should work...
  • OneVoice Network.zip
W2SJW
Senior Member
Northwest NJ
Anytime, sir! With all the help you gave me when I still had my APX, I'm forever in your debt!
rr60
KVL 7000
Thank-you
Appreciate that.
N2ICV
Gloucester County FM29in
http://info.uniden.com/twiki/pub/UnidenMan4/Digitalmobileradioupgrade/DMR_RC_3.zip
Mind you - there is NO DB support yet for DMR (it won't even show). You must add things manually via FL. At least it beats using the knob & keypad!
Now upto RC_4
Posted, now. No change to Sentinel (if you are fast, you'll get a file w/o Sentinel in it, but I just realized that I need to add Sentinel to that file for those who might just be joining).
Like Crack for a Scanner Addict
rr60
KVL 7000
Changes from the notepad RC_4
- New Supported and Modified Items --
1. Modified delay time working in CAP Plus
2. Modified judgement of DMR type
3. Added unit ID display in Conventional DMR
4. Supported some kinds of DMR ID display and recoding in Quick Search
5. Supported some kinds of DMR ID display and recoding in Custom Search, in case of the name is Custom 0 to 9
6. Added DMR slot display in Search with Scan
7. Added DMR slot display in Close Call Hits with Scan
8. Modified the issue of no resume scan after DMR or P25 conversation in Priority DND
W2SJW
Senior Member
Northwest NJ
I haven't heard from you guys in a few days - how's my FL working for you?
robertpearsall
Edison, NJ
Ok here is my take on it, the FL list you made helps but I I only get one bar which is not enough to decide even with trying different antannas.I think Uniden did a great job on this but DMR just is not for me (will stay with my APX Yes Scott still have mine Thank You)I will wait until the final firmware to decide what I do with the scanner either way I will always stand behind uniden for reasons I will only tell our friend UPMan.
