Op25 and Bias-t
Watton925
Trying to figure out how to add a Lna to my op25 setup how would I go about activating it in op25 command line.
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
I might not have the answer regardless, but I can tell you that you haven't given enough information to start with.
Whomever gives you an answer will need to know what hardware you are using. Airspy, RTL Dongle, SDRPlay, something else? If an RTL Dongle, are you sure it is one that built-in bias-tee support?
Mike
boatbod
Talbot Co, MD
The --args parameter is passed to the driver, so just set it as needed for your hardware on the command line and it will go through.
Watton925
Not sure what you mean by above response can you give a example of what you mean.
boatbod
Talbot Co, MD
