Stream settings backup
maredzki
Hello!
Not sure if this is the best way but for backup and quick rebuild of the environment, is it recommended to backup this directory:
/op25/op25/gr-op25_repeater/apps
I assume restoring would be a bit trickier but at least one has all of the settings backed up.
I'm looking for recommendations for a quick rebuild in case my rpi goes to rpi heaven for whatever reason.
Thanks much!
Marek
maredzki
This must be a tough question, unless it is so obvious than does not warrant an answer lol
blantonl
Founder and CEO
Staff member
Super Moderator
Dallas, TX
This is an OP25 related topic, which is a highly complex monitoring topic.
But yes, that's where all your config files are for op25, so yes, backing that up will be the way to go. But you'll only want to restore the config files and shell scripts only, not anything else there
maredzki
Thank you for your response, I much appreciate it. It would definitely make sense that text files with config be used as a reference if syntax changes in the future releases of OP25. Better have them than not :)
Once again, thank you!
