OP25 op25 assistance with control/voice channels in configs
sean_
las vegas, nevada
Hello,
I'm requesting help with knowing which control channels to use in the op25 (boatbod version) for my area:
---Hardware components----
Computer
Code:
NAME="Linux Mint"
VERSION="22.2 (Zara)"
ID=linuxmint
ID_LIKE="ubuntu debian"
PRETTY_NAME="Linux Mint 22.2"
VERSION_ID="22.2"
HOME_URL="https://www.linuxmint.com/"
SUPPORT_URL="https://forums.linuxmint.com/"
BUG_REPORT_URL="http://linuxmint-troubleshooting-guide.readthedocs.io/en/latest/"
PRIVACY_POLICY_URL="https://www.linuxmint.com/"
VERSION_CODENAME=zara
UBUNTU_CODENAME=noble
SDR Dongle
Nooelec RTL-SDR v5 SDR
Antenna
Diamond Antenna Dual-Band HT Antennas RH77CA
Antenna base
WT60 Magnetic Mount Base
I installed op25 from git source without any complications, and I can run the app with this:
Code:
./rx.py -l 'http:0.0.0.0:8000' --args 'rtl' --gains 'lna:49' -T trunk.tsv -q -1 -2 -S 1000000  -P symbol -o 50000
Code:
$ cat trunk.tsv
"Sysname"       "Control Channel List"  "Offset"        "NAC"   "Modulation"    "TGID Tags File"        "Whitelist"     "Blacklist"     "Center Frequency"
"P25 SYSTEM"    "852.050"       "0"     "0"     "cqpsk" ""      ""      ""      ""
"P25 SYSTEM2"   "852.800"       "0"     "0"     "cqpsk" ""      ""      ""      ""
Problem is I don't see any data appear on the webpage. There is activity on the plots, but I don't know what should appear.
I've also tried with boatbod's multi_rx.py and enabled http but I still don't see any data coming in.
Code:
$ ./multi_rx.py -c p25_single_rtl_example.json
I know my sdr is fine, because I can use gqrx and tune to a FM station, and I installed rtl_airband from src and it's able to receive airband traffic.
I think I'm just confused on how to establish the control channels and voice channels.
Any suggestions?
Thanks!
imonitorit
New London County, Connecticut
I had boatbod version running on an older version of linux mint. In your trunk.tsv file, double check the correct location for "cqpsk" it should line up under Modulation. Also, I'm not sure if the NAC (46B) is required as well.
sean_
las vegas, nevada
Okay, i've made good progress! I just updated the control channel and then i started seeing things on the webpage and hearing audio!!
Now I'm trying to figure out how to have audio piped into icecast so that I can listen to it remotely.
Anyone have ideas about that?
