MCWKen
After setting up the desktop, and running OP25 in VirtualBox, the audio still is not totally being decoded. I have spent the better part of the week trying to tweak it referring to the many posts here.
When initiated, the TBSKS shows active until a voice channel is noted, the system tunes to that voice channel, and TBSKS stops.
Command Line:
./rx.py --args 'rtl' --gains 'lna:45' -T trunkmusc.tsv -S 960000 -X -x 1 -l http:127.0.0.1:8080 -2 -w -V -v 11 2> stderr.2
If I were to set -S to 250000, I will get a little bit more voice, but again it is not being processed thoroughly.
And advice to what needs to be changes would be appreciated.
Command Line:
