OP25 OP25 (Boatbod) compiled on arch no sound
excentric
I recompile OP25 gr310 branch and every compiled fine (arch) but when I run :
./rx.py --args "rtl" --gains 'lna:46' -S 960000 -X -q 0 -v 1 -2 -V -U -T trunk.tsv 2> stderr.2
I get this error in my Stderr.2:
sing Python /usr/bin/python3
gr-osmosdr 0.2.0.0 (0.2.0) gnuradio 3.10.9.2
built-in source types: file rtl rtl_tcp uhd hackrf bladerf rfspace airspy soapy redpitaya
Using device #0 Realtek RTL2838UHIDIR SN: 00000001
Found Rafael Micro R820T tuner
[R82XX] PLL not locked!
gain: name: LNA range: start 0 stop 49 step 0
setting gain lna to 46
supported sample rates 250000-2560000 step 24000
demodulator: xlator if_rate=24000, input_rate=960000, decim=40, taps=193, resampled_rate=24000, sps=5
op25_audio::eek:pen_socket(): enabled udp host(127.0.0.1), wireshark(23456), audio(23456)
p25_frame_assembler_impl: do_imbe[1], do_output[0], do_audio_output[1], do_phase2_tdma[1], do_nocrypt[0]
metadata update not enabled
using ALSA sound system
audio device: default
Listening on 127.0.0.1:23456
python version detected: 3.11.8 (main, Feb 12 2024, 14:50:05) [GCC 13.2.1 20230801]
03/24/24 11:23:27.179068 Reconfiguring NAC from 0x000 to 0x3a2
03/24/24 11:23:27.864920 voice update: tg(2405), freq(856812500), slot(0), prio(3)
03/24/24 11:23:30.322197 voice update: tg(1451), freq(853650000), slot(0), prio(3)
Exception in thread Thread-3:
Traceback (most recent call last):
File "/usr/lib/python3.11/site-packages/numpy/core/fromnumeric.py", line 59, in _wrapfunc
return bound(*args, **kwds)
File "/usr/lib/python3.11/site-packages/numpy/core/_methods.py", line 99, in _clip
return um.clip(a, min, max, out=out, **kwargs)
numpy.core._exceptions._UFuncOutputCastingError: Cannot cast ufunc 'clip' output from dtype('float32') to dtype('int16') with casting rule 'same_kind'
During handling of the above exception, another exception occurred:
File "/usr/lib/python3.11/threading.py", line 1045, in _bootstrap_inner
self.run()
File "/home/gene/radio/op25/op25/gr-op25_repeater/apps/sockaudio.py", line 553, in run
self.sock_audio.run()
File "/home/gene/radio/op25/op25/gr-op25_repeater/apps/sockaudio.py", line 468, in run
data_a = self.scale(data_a)
File "/home/gene/radio/op25/op25/gr-op25_repeater/apps/sockaudio.py", line 486, in scale
arr = np.clip(arr*self.audio_gain, -32767, 32766, out=result)
File "/usr/lib/python3.11/site-packages/numpy/core/fromnumeric.py", line 2169, in clip
return _wrapfunc(a, 'clip', a_min, a_max, out=out, **kwargs)
File "/usr/lib/python3.11/site-packages/numpy/core/fromnumeric.py", line 68, in _wrapfunc
return _wrapit(obj, method, *args, **kwds)
File "/usr/lib/python3.11/site-packages/numpy/core/fromnumeric.py", line 45, in _wrapit
result = getattr(asarray(obj), method)(*args, **kwds)
03/24/24 11:23:37.290059 voice update: tg(1451), freq(856487500), slot(1), prio(3)
Not sure but I see that its realated to the sockaudio.py . Anybody have any suggestions?
boatbod
Talbot Co, MD
The particular piece of sockaudio.py code that triggers the error is this:
Code:
    def scale(self, data):  # crude amplitude scaler (volume) for S16_LE samples
        arr = np.array(np.frombuffer(data, dtype=np.int16), dtype=np.float32)
        result = np.zeros(len(arr), dtype=np.int16)
        return result.tobytes('C')
It's purpose is to convert from floating point samples used internally by op25 into int16 samples used by pulse/alsa sound system.
Nothing has changed in this code, so I can only assume your version of numpy got updated and now it doesn't like what previously worked.
ETA: further research shows that default numpy.ufunc casting rules were changed from "unsafe" to "same_type" in version 1.10
I have posted a fix which should get things working again.
excentric
Code:
Ok it works like a charm
I figured out what you meant by you posted a fix
