I'm trying to set up the most basic ability to receive FM on an RTL-SDR dongle on an Raspberry Pi 4.
I can use SDR++ fine on the Pi, although the calibration is off by a bit. I am taking that offset into consideration in my testing.
What I'm trying to do at this point is transmit on 2m FM (I'm an amateur radio operator) and hear this on my Pi through the headphone jack. This should be the most basic possible configuration. I'm using multi_rx.py because I believe I need it for analog FM, and for multiple channel support?
I am not getting a PLL lock, and it's not clear if that is the issue or not. Is this a valid setup to receive FM at 147.442800 MHz and play it through the headphone output?
JavaScript:
"channels": [
"name": "voice channel",
"device": "sdr0",
"trunking_sysname": "test",
"destination": "udp://192.168.1.55:23456",
"frequency": 147442800,
"enable_analog": "on",
"nbfm_deviation": 4000,
"nbfm_squelch": -60,
"demod_type": "cqpsk",
"filter_type": "widepulse",
"excess_bw": 0.2,
"if_rate": 24000,
"symbol_rate": 4800,
"plot": ""
"devices": [
"args": "rtl=0",
"gains": "LNA:39",
"gain_mode": false,
"name": "sdr0",
"offset": 0,
"ppm": 0,
"rate": 1000000,
"usable_bw_pct": 0.85,
"tunable": true
"trunking": {
"module": "tk_p25.py",
"chans": [
"nac": "0x0",
"sysname": "test",
"control_channel_list": "147.4428",
"whitelist": "",
"blacklist": "",
"tgid_tags_file": "trunk-tags.tsv",
"rid_tags_file": "trunk-rids.tsv",
"tdma_cc": false,
"crypt_behavior": 2
"audio": {
"module": "sockaudio.py",
"instances": [
"instance_name": "audio1",
"device_name": "default",
"udp_port": 23456,
"audio_gain": 1.0,
"number_channels": 1
"terminal": {
"module": "terminal.py",
"terminal_type": "curses",
"#terminal_type": "http:127.0.0.1:8080",
"curses_plot_interval": 0.1,
"http_plot_interval": 1.0,
"http_plot_directory": "../www/images",
"tuning_step_large": 1200,
"tuning_step_small": 100
Code:
Using Python /usr/bin/python3
Starting OP25 (pid = 41953)
Configuring audio instance #0 [audio1]
using ALSA sound system
audio device: default
Listening on 127.0.0.1:23456
01/18/24 16:24:45.810971 [test] Initializing P25 system
01/18/24 16:24:45.811124 [test] reading system tgid_tags_file: trunk-tags.tsv
read_tags_file: exception [Errno 2] No such file or directory: 'trunk-tags.tsv'
01/18/24 16:24:45.811292 [test] reading system rid_tags_file: trunk-rids.tsv
read_rid_file: exception [Errno 2] No such file or directory: 'trunk-rids.tsv'
Enabled trunking module: tk_p25.py
device: {'args': 'rtl=0', 'gains': 'LNA:39', 'gain_mode': False, 'frequency': 147442800, 'name': 'sdr0', 'offset': 0, 'ppm': 0, 'rate': 1000000, 'usable_bw_pct': 0.85, 'tunable': True}
Device name: "sdr0", osmosdr args: "rtl=0"
gr-osmosdr 0.2.0.0 (0.2.0) gnuradio 3.10.5.1
built-in source types: file fcd rtl rtl_tcp uhd hackrf bladerf rfspace airspy airspyhf soapy redpitaya freesrp xtrx
Using device #0 Generic RTL2832U SN: 77771111153705700
Found Rafael Micro R820T tuner
[R82XX] PLL not locked!
gr-osmosdr driver gain_mode: False
Exact sample rate is: 1000000.026491 Hz
channel (dev sdr0): {'name': 'voice channel', 'device': 'sdr0', 'trunking_sysname': 'test', 'destination': 'udp://192.168.1.55:23456', 'frequency': 147442800, 'enable_analog': 'on', 'nbfm_deviation': 4000, 'nbfm_squelch': -100, 'demod_type': 'cqpsk', 'filter_type': 'widepulse', 'excess_bw': 0.2, 'if_rate': 24000, 'symbol_rate': 4800, 'plot': ''}
demodulator: xlator if_rate=24000, input_rate=1000000, decim=41, taps=197, resampled_rate=24390, sps=5
op25_audio::open_socket(): enabled udp host(192.168.1.55), wireshark(23456), audio(23456)
01/18/24 16:24:46.819224 [0] Enabling nbfm analog audio
01/18/24 16:24:46.833825 [0] Initializing P25 receiver: voice channel
01/18/24 16:24:46.834014 [0] metadata updates not enabled
Flowgraph complete. Exiting
