op25 help!
kc8zmp
alma michigan
need help setting up the talkgroup.tsv this is the error in stderr.2
Skipping invalid row in mp.tsv: ['32001', 'DPDCID50']
Skipping invalid row in mp.tsv: ['32003', 'DPDCID51']
Skipping invalid row in mp.tsv: ['65535', '10LAW1']
No valid trunking configs. Aborting!
trunk file
"Sysname" "Control Channel List" "Offset" "NAC" "Modulation" "TGID Tags File" "Whitelist" "Blacklist" "Center Frequency"
"P25 SYSTEM" "853.47500" "0" "0x790" "C4FM" "mp.tsv"
this is my command line ~/op25/op25/gr-op25_repeater/apps$ ./rx.py --args 'rtl' -N 'LNA:47' -S 2400000 -f 853.475e6 -o 25000 -q -0 -T mp.tsv -V -2 -U 2> stderr.2
NebraskaCoder
Omaha, NE
OP25 is very strict. I can't remember off the top of my head but BOTH the trunk file and TGIDs files need either spaces or tabs between columns (one one).
kc8zmp
alma michigan
It's tabs. Followed the op25 for dummies video and modified the TG file and saved it but getting "invalid row" in my TG file mp.tsv
boatbod
Talbot Co, MD
The format for the trunk-tags.tsv file is one <TAB> character between each field, spaces allowed within the fields themselves.
[tgid]<TAB>[tg description]<TAB>[priority]
Note that the 'priority' field is optional and defaults to 3 if not specified. Lower numbers represent a higher priority and will allow preemption of calls in progress on lower priority tgids.
wgbecks
NE Wisconsin
It's very helpful to use a text editor having the capability to display hidden characters. Another suggestion is to run your files
through dos2unix. To install: <sudo apt-get install dos2unix>. Then invoke. Example: dos2unix trunk.tsv and it will parse the file
in an attempt to clean (remove) formatting remnants left behind from creation or editing that was done on a Windows machine.
boatbod
Talbot Co, MD
So editing the tsv file in txt editor is ok as long as you have the tabs?
Yes, as long as your editor of choice does not substitute spaces for tabs. Personally I use gvim (or vi) but I'm definitely old-school and would hardly recommend it to someone unfamiliar with linux.
boatbod
Talbot Co, MD
Looks like two rows of the mich.tsv file have invalid characters. That sometimes happens with RR cut & paste. Edit them, or delete them entirely.
kc8zmp
alma michigan
saved these as txt files so you could see. still don't know whats going on
i'm in Isabella county and on the control frequency
thanks for all the help
  • stderr.2.txt
  • trunk.txt
