OP25 Web Interface
Covack
God's Country
I'm sure this has been ask already
I have op25 up and running, with web interface no problems
Can I access this on a remote computer, say at work using a chrome browser or vlc
rivardj
Michigan
Yes, if you are able to access the the system op25 is running on from outside your network. Your router has to be setup properly to allow this to work.
wgbecks
NE Wisconsin
A note of caution!!! Don't expose OP25's Web GUI, or your Linux system (VLC) directly to the internet. Instead, it's quite easy to setup
a "Reverse Proxy" using NGINX that will at least require the remote user to supply Username/Password credentials.
bucket772
Or a VPN setup on your home network and remote in. Been doing that for years. As wgbecks said, and has been echoed many, many, times, there is no security with OP25 and opening port forwarding, well might as well take the front door off of your house
dave3825
Suffolk County NY
I have Boatbod installed on a PI and on a Nuc and have used Teamviewer since it can carry audio. I also use tightvnc but forget is that carries audio. On the pi I did not go headless so an HDMI emulator is used.
Covack
God's Country
I decided to go the liquid soap and icecast2 darkice route
I did this a few years back, I'm lost as I was back then
I got liquid soap and icecast2 installed
I put in username and password in icecast2 during setup
I started op25
I tried logging in to see if I had anything
says username or password is incorrect
How do I go back and check that on terminal
I tried sudo /usr/bin/icecast2
It was a no go
