Optocom
mikeb
DFW
Trying to get my Optocom working. I use PROBE software and needing help with a older computer getting DOS to interface with it. Are there any local DFW repair shops that are familiar with DOS?
KG5YOU
Houston
Hi Mike,
In my experience with the DOS OS on modern machines, VirtualBox or DOS-BOX are pretty good options when it comes to emulating the way DOS used to run and the hardware it used. Another mention is that there have been documented instances where certain CPUs operate at frequencies that make it *almost* incompatible when communicating with older devices due to a way that the frequency of the messages/signals on the line is timed.
If you have a specific question in getting the device to work with your software I may be able to help; but have no experience with traffic devices or infrastructure. Do you currently have any errors or is it just not recognizing your device?
k4fv
Dania Beach, FL
If you are booting DOS and not running under windows or an emulator you’ll need a true serial port. Serial port cards are available with a 16550 UART which provide native support. No drivers required.
