G8OEO
I've been happily remote controlling the AR5700D using the USB interface but there is a serious limit to the acceptable USB cable length from radio to PC
Every time I want to play around editing memories etc I have to move the radio from it's usual position to be much closer to the computer, so I thought I would try out the RS232 socket instead which should be OK for the ~20ft run involved.
A female 9 pin socket is required on both of the cable ends so it was my guess that a null modem cable would be the correct approach. Unfortunately having definitely selected the correct com port in the PC software the radio is not responding at all.
Has anyone succeeded using RS232 control on this radio, or with the 5001D which is very similar?
