Orange County visit
thomasbillman1
Mesa
hello, i am staying in Anaheim from June 14 to June 21 bringing my sds200 with me. Looking to listen to fire and forestry. Can you guild me what to down load please Very confusing when your not from there and you look under radio reff and man so much to find out what to down load. Thank you very much. I have a scanner group here in arizona, retired fire fighter. thank you for any help you can give me. Thomas
Ravenfalls
OC Trunked System
OC ^ system has no fire to listen to, ENC.
Everything you want is listed in the RR DB. USFS has maps of their lands. Check out CA State Parks. CA CDF x county around Orange County. LAPD another option. Too much to list as many agencies have wide area coverage.
In this forum, read posts past year or two as that should answer your questions.
Federal forum will definitely answer ALL your USFS questions.
thomasbillman1
Mesa
i went as far back as 2023, i dont see anything listed as orange county, what does fire run off of what system. thank you remember i am not from there going on vacation to disney land for the week.
MiCon
Mike
central AZ
I don't have time to list all agencies & frequencies. It sounds like you're interested in wild fire activity. Orange County is surrounded by the Angeles, San Bernardino, and Cleveland NF's.
Cal Fire operates in Riverside and San Bernardino Counties. Mountain top repeaters easily heard in OC. Also San Bernardino and Riverside County FD's.
Go back to RR database and program the frequencies listed for the above agencies, but just the repeaters.
There's also LA Co FD, but there's so much junk there that it's hard to pick out the good calls, and it will slow down your scan rate.
Have fun at the Magic Kingdom.
Eng74
Kern County, CA
Depending on where you are staying in Anaheim you can get LACoFD, sometimes LAFD. All of Orange County Fire is encrypted. You can load the Solar plan, which is for LACoFD and OCFA on VHF. You can also scan Verdugo which is a lot of the cities in SoCal.
gabrielm
This is a bit late, but since you have a couple more days here… your best bet is Broadcastify. OC Fire Authority broadcasts many of its dispatch/response channels online. Anaheim specifically is part of Metro Net, and their dispatch / response channels are also streamed online. Anaheim and OCFA are also on PulsePoint. The only thing you can’t get right now is structure fires in Anaheim. They are testing a new plan where structures utilize two channels (2C for tactical and 2O for command), and neither channel is currently streamed. There is a plan to fix that in the future.
LB_Scan
Hi
Its so fanny on how can Broadcastify. OC Fire Authority broadcasts. and yet on my digital scanner i can not listed to it because Orange County Fire decided to have there channels encrypted
Eng74
Kern County, CA
Hi
There were changes to the chiefs of the OC fire department before the P25 system went into service who decided to go unencrypted, but the cost at the time would be too much and them putting the feed on Broadcastify was the easiest thing they could do.
LB_Scan
Hi @Eng74
Is that the same thing with signal hill PD on unencrypted on broadcastify. thanks
iscanvnc2
Ventura, CA
No mention has been made of
151.010154.965123.0 PLWNIG250OC Fire Tactical / Outside Agency Access
Yesterday, July 7, I was able to monitor command for the Rancho fire in Laguna Beach from by home here in Ventura city.
Eng74
Kern County, CA
That is part of the SOLAR radio plan that is used for OC/LACoFD/CDF for brush incidents.
es93546
A Member Twice
Right Side of CA on maps
SOLAR in this case stands for San Bernardino, Orange, Los Angeles and Riverside. This particular area gets activity that can, at times, affect many of these jurisdictions due to the boundaries of each and fires that cross these jurisdictional lines.
AEFI
East Valley San Bernardino County
SBcFD has the following in the SOLAR band-plan: CDF C1-3, FIRE OC, OC ACCESS, LAC V-1 and 2, RRU 2, VFIRE 22-26, LAC A/G, CDF A/G 1, 3, and AIRGUARD
