oregon info please
fshndean
should i or can i put Portland boec on the same bank as clackamas county and then ad the talk groups or should i put Portland on bank one and clackamas on bank 2 ? if portland and clack are both boec does it matter ? also what should my settings be on my bct8 to get the best performance ?
base freq ?
toggle status bit ?
control channel settings ?
any help would be great..
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Obviously someone didn't read the part where location based questions should go to that forum. I'll request this to be moved .
73 Mike
PNW
Portland should be in its own bank, and Clackamas Co. in another.
Portland and Multnomah Co. share a trunked system, while Washington and Clackamas Co. share a different trunked system.
You should be able to follow the systems by using the control channel feature on your BCT-8.
Hopefully some of the Portland area folks can chime in about the other info you need.
fshndean
thanks treehuger, and for the guy that is scolding me for posting in the wrong place, (take a chill pill)
PMJ2kx
Curious Onlooker
Utah County, Utah
Oh, you mean that guy that has "Wiki admin" as a title? Methinks you won't make many friends by telling others (especially mods or admins) to chill. He's just trying to keep things in order. ;)
You may or may not be aware of rebanding for CCOM (Clackamas), so make sure when the update comes out for your BCT8 that you update the firmware. The new frequencies can be found here, although I don't believe they're active yet:
http://www.radioreference.com/apps/db/?sid=3136
As I don't listen to, nor follow the BOEC's goings on, I'm not sure what they're doing for rebanding.
fshndean
whoops
sorry methinks i thought you were just being sarcastic. my bad...
DickH
base freq ?
toggle status bit ?
B.O.E.C. is Bureau of Emergency Communications for Portland & Multnomah county. Nothing to do with Clackamas.
No need for base freq.. Don't worry about status bits.
I believe the BCT8 programming is the same as the PRO-433. If you join this group (free), the FILES section has step by step programming, including Conrol Channel only programming and a simple explanation about trunking.
http://groups.yahoo.com/group/PRO-433_scanners
Here are the control channels for the 4 counties in the Portland area.
You can find a list of talk groups in the RadioReference.com database.
Multnomah
858.7125
858.7375
859.2625
859.4625
Clackamas
867.4375
867.8625
868.2625
868.7625
Clark
859.7625
859.9375
860.7625
860.9375
Washington
859.2375
859.7375
860.2375
860.7375
Dick
