Ottawa MTO
mmisk
Ottawa Canada
It is always good to read posts where the poster supplies the solution to the problem. This helps anyone having a similar or the same issue and reading the thread. Good work mmisk.
Well guess what?
The problem has returned.
Problem review:
When an analog FleetNet TG is active, UT voice VFO will tune to the correct frequency, however no audio.
Digital TG's are heard fine.
So this time I will do a fresh install of an older UT version and see what happens.
Will do this ASAP.
Mike
mmisk
Ottawa Canada
I've had similar issues with UT. For me it was squelch settings on the voice VFO's. Lowering the squelch level fixed it.
Thanks VE3JPX, if it happens again I will try that.
I did a reload of Ver. 22 and it is fine for now.
mmisk
Ottawa Canada
My squelch is set to -60 for both signal & voice.
OK thanks!
Mine is also at 60 so if the trouble returns I will reduce it.
Unitrunker is a great application, have been using it for years.
When OPS went to EDACS ProVoice long ago, I used UT to track the PV talkgroups, and then send the codes from UT to a Uniden scanner.
The Uniden would then track only the PV talkgroups. Then I would send the raw audio to a computer via a discriminator tap.
An older version of DSD+ would decode the audio. I could listen and follow a ProVoice conversation this way.
Talk about jumping through hoops to track and listen to ProVoice, but what fun.
Aviator747
Cornwall, ON
OK thanks!
60 or Negative 60?
gary123
Negative 60. Positive 60 would set the threshold so high you could TX 30 watts into the SDR and not break squelch. No do not ever TX into a SDR for any reason. In fact it's a good idea not to have any TX near the SDR or its antenna.
mmisk
Ottawa Canada
Thanks for this, yes I should have posted -60.
Have been running UT often and things have been working very well no more issues with the analog talk groups.
