Out of band?
welshevo
hi there im new to the china Transceivers, and have the baofeng uvb5 and also the vero UVX5 which is the same as the baofeng uvr3? i would like to be able to program slightly out of band? is this possible the radio is capable of Frequency Range: 136-174, 200.025-260 & 400-470MHz but i need 176-200mhz?
is this at all possible? i know you can tweak the .INI file (which i haven't tried yet) but will it actually work or just display the frequencies without actually receiving anything? thanks
jeepinjeepin
Winston Salem, NC
Out of band transmission is in almost all cases quite illegal and may result in substantial fines from the FCC. I would strongly recommend against it.
welshevo
Thanks for the reply i wont be transmitting on the out of band, just observing, and in the uk things are slightly different??
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Please don't assume the poster is under the jurisdiction of the FCC. This is a global website with many members located outside of the USA.
Thanks.
jeepinjeepin
Winston Salem, NC
Sorry, I didn't see this reply earlier. Yeah, you can listen in on any RF that is not encrypted. The dual frequency ranges that you see on some radios are for different regions. They should be noted (US/Europe, US/China, etc). You might have to search out a version that will receive the freq you are interested in. A basic radio scanner is another option.
welshevo
ok so ive managed to edit the . INI of the baofeng uvb 5 software and it allows me to programme from 115.00 MHZ - 520mhz FM ....so i programme the frequenices i want 178.6250 mhz but nothing seems to be heard.... does it mean the radio will "show" you the Freq but not actually recvieve anything? let me know folks!
