BC796D: P25 Audio
ofd8001
Louisville, KY
I've got an ancient 796D - got it when they first came out.
I'm monitoring a P25 Conventional system. When the scanner hits on a frequency it will either buzz for a couple of milliseconds or sound like some form of telemetry. Only rarely will audible voice be heard. I'm monitoring the same frequencies on an SDS 100 and the appropriate audio is heard, so I know encryption or telemetry isn't the issue.
Are there any adjustments to be made to clean up the audio?
tvengr
Well Known Member
Baltimore County, MD
I don't know of any way to set a conventional frequency to digital only. Conventional P25 NAC cannot be used on the 796. Check this thread to see if it is helpful: How to adjust Digital Card - BC796D You will also find that the 796 does not support 700 MHz frequencies. It was manufactured before that band became available.
