Do any of you radio experts have any tips for increasing P25 reception? I've been trying to use an external antenna, which doesn't really seem to work, and just using stock antennas indoors isn't crystal-clear either. Help?
Antennas are frequency dependent, not mode dependent. Making sure you have an external antenna that is designed for the frequency you want to listen to is key.
-There is no such thing as a "P25" antenna, so beware of anyone who tries to sell you such a thing-
Using quality coaxial cable is important. All wire/cable has some amount of inherent loss. Higher frequencies will suffer more from this. Longer cable runs increase the amount of loss. So, make sure you are using the appropriate cable for the application.
Simulcast systems can also create issues. When a system is using multiple sites all using the same frequency, some radios can have a hard time not suffering from interference. In these cases less antenna can work better.
Local interference can be a problem, too. If there are transmitters located close to you, those can desensitize your radio and make it difficult to receive a weaker signal.
If you can provide the information on the agency/system you are trying to listen to, and exactly what sort of antenna and coaxial cable you are currently using, we might be able to offer some suggestions.
