BCD325P2/BCD996P2: P25 site entry into 996p2, basic questions
mscir
Santa Cruz, California
I would like to program these statewide frequencies into my 996p2 to get a P25 site going. These appear to be single frequency trunked sites since no control channel is listed. So is it correct that I enter each one as a separate site, and not as a group under a singe Parks & Recs site for example?
Department of Parks and Recreation (State Parks) (California) Scanner Frequencies and Radio Frequency Reference
Parks & Recs > Lands/Conservation > Statewide
FrequencyLicenseTypeToneAlpha TagDescriptionModeTag
770.68125WPTZ774RM111 NACDPR OPSAdmin/MaintP25Law Tac
773.09375WPTZ774M111 NACDPR T1Tac 1P25Law Tac
773.04375WPTZ774RM222 NACDPR T2Tac 2 (SVRA's)P25Law Tac
770.41875RM111 NACDPR ExtenderVehicle RepeaterP25Law Dispatch
tvengr
Well Known Member
Baltimore County, MD
Those are conventional frequencies. Create a new conventional system or add the frequencies to an existing conventional system. There are no sites involved. Sites are used only for trunked systems.
BinaryMode
Blonde Once Said To Call Her But Never Answerd
75 parsecs this way -->
I own the 996P2 but it's in my car and not in front of me. However my 325P2 is in front of me and the programing should be the same.
Press Menu.
Program System.
New System.
Conventional.
Edit Group.
Edit Channel.
Go back and set audio type to All (default) or Digital. As P25 is the digital voice on these conventional frequencies.
You can also set the P25 NAC as indicated. Not really required.
sonm10
Central MN Monitor
Sauk Centre, Minnesota
There are 2 ways around to it
The method @tvengr suggested is one.
The other method is to program as one-frequency trunk, then create a new site for each frequency. The advantage of using this method is to program talkgroups.
mscir
That's interesting, thanks very much. If I find an active site I like I will look into that approach, when I learn how to ID talkgroups.
cg
Connecticut
It would be very rare to find a conventional P25 channel that uses multiple talkgroup IDs. They may not all use TGID 1 but having multiple groups is not typical.
mscir
I deleted the manually entered site and used Freescan to import it directly from RR with no changes. Still not hearing any traffic.
  • BCD996P2 - added Nat. Interop - 8-13-24.zip
