p25
jlo
mount pearl, NL.
i was looking in the data base for my area and seen p25 province wide seems to be new.
i haven't heard about this.
will this mean the rcmp will be totally unheard. would anyone know if they are using this now.
any details would be great.
davidmc36
South East Ontario
Have not looked up the DB for your area of The Rock but P25 does not mean you will not hear. Encryption would lock you out.
michael7676
newfoundland
Some talkgroups are using phase 2 TDMA modulation that you won't be able to moniter but i haven't come across this system. i can moniter grandfalls and the south coast with no problem's using the control channels haven't got any talkgroups yet
radioman97
Are you monitoring it with a PRO-106 / PSR500 ?? If did you use P25 Auto or Manual? Everything west of clarenville is digital. East still on Edacs Standard.
jlo
mount pearl, NL.
radioman
i was able listen in using both 396xt and pro106
but currently i'm not able to here anything on the avalon.
so i;m wondering if they are completely digital now.
radioman97
Clarenville was audible on 155.400 (chapel arm scat channel) bits and pieces and periodically on the usual edacs listening channels however, rx transmissions have disappeared. In various sections of east nl, the old 155.970 and 155.820 Clarenville channels are outputting digital material indicating a change in operations. Eventually east nl will all be complete.
jlo
mount pearl, NL.
sorry primehifi
i had them showing as digital in the program check box.
all is good though i still have those darn beeps after each trans. but other than that have they gone to digital yet.
also how do i create my own talk group i have three frequency listings that i have been told gets rid of the beeps at the end but i don't know how to do the talkgroup.
michael7676
newfoundland
i have a problem down here on the south coast bay d'espoir i don't know if you have the same problem but it is the system here is running like a scat system but it's p25 vhf uhf can't program it to scan all i can do is program it in conv p25 and the scanner stays on that channel very different
ve1sef
Halifax Regional Municipality, NS, Can
When I was over last June the I found it nessary to have all three system in the 996xt,
P25 for areas west of Clarenville,
EDACS standard for Northern Avalon
Scat for Southern Avalon.
The Scat and EDACS appeared to be simlicast.
I did discover the EDACS ID number for Clarenville is the same ID being used on the P25.
Maybe try the other EDACS talkgroup IDs in the P25, see what happens.
Another thing that caught my attention was that all the vhf frequenices being used by the EDACS & Scat
systems were also being used in the P25 system.
terrahawkone
GF-W, NL, CA
Michael.... What scanner are you using and what is the control trequency you are monitoring?
terrahawkone
GF-W, NL, CA
go and look at my thread( pro 106 problem) in radio shack scanner forum
...Yup, that is a lot of info alright....
159.690 is the voice channel in GFW and as well at the Botwood and Springdale sites. The control is the same channel that was used previously in the analog system before p25 replaced it. I was thinking that if the same convention was used for the rest of the district sites, then maybe, just maybe the same thing was done in Bay d'Espoir and 159.690 is actually the voice channel.
jlo
mount pearl, NL.
same here on the west coast stephenville
i'm having the same problem here it just stuck on the one channel.
i'm sure they have others for this district.
i've tried to scan all and it locks onto just one.
why is this. anyone from west coast confirm what channels are in use.
thx
michael7676
newfoundland
thx
they have the voice ,data and registration all in one control channel no software out to allow you to program this in your scanner for more info go to my thread in radio shack scanners it's called (pro 106 problem)
hfxChris
Dartmouth, Nova Scotia
thx
It sounds as if you don't have it programmed as a P25 trunked system, instead as just a conventional system.
