P5500 PERSDATA ERROR=0500
KG5HHS
D/FW
I have been attempting to program a P5550 (R06D13) with RPM R10B07. I have written a very simple personality to the radio with 1 conventional channel. The process seemed to be successful until the radio rebooted and now displays "P5500 R06D13 SELFTEST" > "PERSDATA ERROR=0500 040F5A34" > "PROGRAM". I had also read in another thread where you can use the radio maintenance tool to "JUMP" the radio. That has been unsucessful. Any help on this topic would be greatly appreciated. Thank you.
Radioman96p71
XGP R06D13 uses the new expanded personality format and requires RPM 14 or later. You need the usual XGP R02A26 for RPM 10
KG5HHS
D/FW
Thank you for the reply. I will be using this radio as the portable for the M7300 radio I use at home with XGP R02A26 used for NAS on a P25 Phase 2 system. Is there anyway to downgrade this radio to XGP R02A26?
Radioman96p71
Yep, just need someone with the firmware to load it into the radio and (ideally) align it. Downgrades are usually pretty safe.
Forts
Ontario, Canada
As mentioned just load R02A26 to it and you should be fine. I've downgraded several radios in the past with no issue.
KG5HHS
D/FW
ah okay, that is good to hear, This seems like a relatively simple solution. Can someone please instruct me how to do that process?
Forts
Ontario, Canada
You will need the proper R02A file for that model radio (obviously).. Then in RPM
Radio -> Standard Serial Connection -> Load Compressed Code
Select your COM port and point RPM to the file. Hit Load and wait patiently!
KG5HHS
D/FW
Thank you for the reply. How do I go about getting the R02A file?
