Pager codes
BryanTheRed
Ø
NC
Looking for the individual tones of pager code 1129 and 1192. Thanks!
BryanTheRed
Ø
NC
Maybe someone can break down the charts I dont understand how you get 1129 and 1192 out of those charts at all.......... BTW its a QC2 paging format! Short long
RBMTS
Usually the 4 digit cap codes are using the Centracom coding method.
The "11" means that you use tone group 1. The "2" and the "9" are the tones numbers in that group. Therefore it should be:
1129 = 368.5 / 539.0
1192 = 539.0 / 368.5
Hope that works for you. Good luck!
BryanTheRed
Ø
NC
OK so the two 1's mean that tone one is from group one as well as tone two?! I think I got it thanks!
bravo14
Polk County FL
That will be correct about the info above. I ran 1129 1192 came up like that. If you need a tone recording I have a program that makes tones A and B.
DickH
If that program is not proprietary, can you share it with the rest of us?
bravo14
Polk County FL
The program can give out its licensed but you can download it and buy it forgot the website when I log in my laptop I'll look it up.
bbreiler
so if "11" means you would use tone group 1, what about "12"? I need to get the codes for QC on a 1261 system....
thank you
RBMTS
thank you
It's really easy if you follow the website link provided by Jay.
Using chart 5 as indicated, "12" means that the first tone is from group two, and the second tone is from group two. Both tones can be found in chart 2.
Tone "6" in group two = 788.5
Tone "1" in group two = 600.9
Hope this helps.
