I'm trying to use a paperclip antenna on my 536 to reduce simulcast distortion. But I can't really find any images of how it is supposed to be bent. Should it just be a straight wire pointing up, or should it be bent into a certain shape?
Just use the attenuator function. but if you must use the paperclip then it must be PERFECTLY shaped like a Z.I'm trying to use a paperclip antenna on my 536 to reduce simulcast distortion. But I can't really find any images of how it is supposed to be bent. Should it just be a straight wire pointing up, or should it be bent into a certain shape?
I thought it was shaped like a "Q"Just use the attenuator function. but if you must use the paperclip then it must be PERFECTLY shaped like a Z.
Scan On!
I agree with bob550 about using a sacrificial adaptor between the radio and paperclip. Paperclips can spring the contact cup on a panel mounted BNC connector. Having worked R&D/Production support I have replaced many contacts that were probed with objects to big for the tasks.If you're intent on using a paperclip, I'd recommend the use of a right-angle BNC adapter between the scanner and paperclip. That way, you're not potentially damaging the antenna input on the scanner.
.... The Coiled Antenna is Superior. It amplifies power by going in circles...
That is not the purpose of a yagi antenna and sometimes that backfired because you had a Tower behind you and in front of you at equal distances.
